How to fix errors in Hassio
Background:
I’m not a programmer and don’t work with computers. I have never used anything but windows until I installed Hassio on my Ras Pi 3. I don’t have a scooby about python or linux but I have the awesome combination of google, enthusiasm and you guys!
Issue:
I recently updates hassio to 59.1 and seem to have a fair few erros in my config and some weather stuff and sesnsorrs aren’t working.
Questions:
Can I fix them? How do I do this? Can you get into the “behind the scenes” code and fix errors in hassio?
How can I diagnose issues? The error logs are mostly gibberish to me!
2017-12-05 20:12:20 ERROR (MainThread) [homeassistant.components.sensor] Error on device update!
  File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 141, in _new_conn
    (self.host, self.port), self.timeout, **extra_kw)
  File "/usr/lib/python3.6/site-packages/urllib3/util/connection.py", line 60, in create_connection
    for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
  File "/usr/lib/python3.6/socket.py", line 743, in getaddrinfo
    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 601, in urlopen
    chunked=chunked)
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 346, in _make_request
    self._validate_conn(conn)
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 850, in _validate_conn
    conn.connect()
  File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 284, in connect
    conn = self._new_conn()
  File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 150, in _new_conn
    self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x74145690>: Failed to establish a new connection: [Errno -3] Try again
  File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 440, in send
    timeout=timeout
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 639, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/usr/lib/python3.6/site-packages/urllib3/util/retry.py", line 388, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='transportapi.com', port=443): Max retries exceeded with url: /v3/uk/train/station/HNW/live.json?app_id=763ed0c7&app_key=7e5a9129b8d2144c00c9d1d9db93f3c0&darwin=false&calling_at=GLC&train_status=passenger (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x74145690>: Failed to establish a new connection: [Errno -3] Try again',))
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py", line 217, in async_add_entity
    yield from entity.async_device_update(warning=False)
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 306, in async_device_update
    yield from self.hass.async_add_job(self.update)
  File "/usr/lib/python3.6/asyncio/futures.py", line 331, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.6/asyncio/tasks.py", line 244, in _wakeup
    future.result()
  File "/usr/lib/python3.6/asyncio/futures.py", line 244, in result
    raise self._exception
  File "/usr/lib/python3.6/concurrent/futures/thread.py", line 55, in run
  File "/usr/lib/python3.6/site-packages/homeassistant/util/__init__.py", line 306, in wrapper
    result = method(*args, **kwargs)
  File "/usr/lib/python3.6/site-packages/homeassistant/components/sensor/uk_transport.py", line 231, in _update
    self._do_api_request(params)
  File "/usr/lib/python3.6/site-packages/homeassistant/components/sensor/uk_transport.py", line 130, in _do_api_request
    response = requests.get(self._url, params=request_params)
  File "/usr/lib/python3.6/site-packages/requests/api.py", line 72, in get
    return request('get', url, params=params, **kwargs)
  File "/usr/lib/python3.6/site-packages/requests/api.py", line 58, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 508, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 618, in send
    r = adapter.send(request, **kwargs)
  File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 508, in send
    raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='transportapi.com', port=443): Max retries exceeded with url: /v3/uk/train/station/HNW/live.json?app_id=763ed0c7&app_key=7e5a9129b8d2144c00c9d1d9db93f3c0&darwin=false&calling_at=GLC&train_status=passenger (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x74145690>: Failed to establish a new connection: [Errno -3] Try again',))
2017-12-05 20:12:23 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over 10 seconds.
2017-12-05 20:12:23 WARNING (MainThread) [homeassistant.setup] Setup of weather is taking over 10 seconds.
2017-12-05 20:12:24 WARNING (MainThread) [homeassistant.setup] Setup of notify is taking over 10 seconds.
2017-12-05 20:12:25 WARNING (MainThread) [homeassistant.setup] Setup of media_player is taking over 10 seconds.
2017-12-05 20:12:25 WARNING (MainThread) [homeassistant.setup] Setup of device_tracker is taking over 10 seconds.
2017-12-05 20:12:25 WARNING (MainThread) [homeassistant.setup] Setup of light is taking over 10 seconds.
2017-12-05 20:12:25 WARNING (MainThread) [homeassistant.setup] Setup of switch is taking over 10 seconds.
2017-12-05 20:12:31 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform xbox_live
    chunked=chunked)
    conn.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x73fa4870>: Failed to establish a new connection: [Errno -3] Try again
    timeout=timeout
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='xboxapi.com', port=443): Max retries exceeded with url: /v2/2535430722633866/profile (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x73fa4870>: Failed to establish a new connection: [Errno -3] Try again',))
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py", line 171, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
  File "/usr/lib/python3.6/asyncio/tasks.py", line 352, in wait_for
    return fut.result()
  File "/usr/lib/python3.6/site-packages/homeassistant/components/sensor/xbox_live.py", line 38, in setup_platform
    new_device = XboxSensor(hass, api, xuid)
  File "/usr/lib/python3.6/site-packages/homeassistant/components/sensor/xbox_live.py", line 60, in __init__
    profile = self._api.get_user_profile(self._xuid)
  File "/usr/lib/python3.6/site-packages/xboxapi/xbox_api.py", line 45, in get_user_profile
    res = self.request("https://xboxapi.com/v2/{}/profile".format(xuid))
  File "/usr/lib/python3.6/site-packages/xboxapi/xbox_api.py", line 111, in request
    res = requests.get(url, headers=headers)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='xboxapi.com', port=443): Max retries exceeded with url: /v2/2535430722633866/profile (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x73fa4870>: Failed to establish a new connection: [Errno -3] Try again',))
2017-12-05 20:12:33 WARNING (MainThread) [homeassistant.components.sensor.yr] Retrying in 15 minutes: Cannot connect to host aa015h6buqvih86i1.api.met.no:443 ssl:True [Try again]
2017-12-05 20:12:34 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform metoffice
    chunked=chunked)
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 357, in _make_request
    conn.request(method, url, **httplib_request_kw)
  File "/usr/lib/python3.6/http/client.py", line 1239, in request
    self._send_request(method, url, body, headers, encode_chunked)
  File "/usr/lib/python3.6/http/client.py", line 1285, in _send_request
    self.endheaders(body, encode_chunked=encode_chunked)
  File "/usr/lib/python3.6/http/client.py", line 1234, in endheaders
    self._send_output(message_body, encode_chunked=encode_chunked)
  File "/usr/lib/python3.6/http/client.py", line 1026, in _send_output
    self.send(msg)
  File "/usr/lib/python3.6/http/client.py", line 964, in send
    self.connect()
  File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 166, in connect
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x73e82790>: Failed to establish a new connection: [Errno -3] Try again
    timeout=timeout
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='datapoint.metoffice.gov.uk', port=80): Max retries exceeded with url: /public/data/val/wxfcs/all/json/sitelist/?key=fd532e24-e590-45f9-9dd3-68504ba4e317 (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x73e82790>: Failed to establish a new connection: [Errno -3] Try again',))
    return fut.result()
  File "/usr/lib/python3.6/site-packages/homeassistant/components/sensor/metoffice.py", line 92, in setup_platform
    longitude=longitude)
  File "/usr/lib/python3.6/site-packages/datapoint/Manager.py", line 187, in get_nearest_site
    sites = self.get_all_sites()
  File "/usr/lib/python3.6/site-packages/datapoint/Manager.py", line 147, in get_all_sites
    data = self.__call_api("sitelist/")
  File "/usr/lib/python3.6/site-packages/datapoint/Manager.py", line 102, in __call_api
    req = requests.get(url, params=payload)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='datapoint.metoffice.gov.uk', port=80): Max retries exceeded with url: /public/data/val/wxfcs/all/json/sitelist/?key=fd532e24-e590-45f9-9dd3-68504ba4e317 (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x73e82790>: Failed to establish a new connection: [Errno -3] Try again',))
2017-12-05 20:12:34 WARNING (MainThread) [homeassistant.components.sensor] Setup of platform plex is taking over 10 seconds.
2017-12-05 20:12:36 ERROR (MainThread) [homeassistant.components.weather] Error while setting up platform metoffice
    chunked=chunked)
    self.send(msg)
    self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x73f43fb0>: Failed to establish a new connection: [Errno -3] Try again
    timeout=timeout
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='datapoint.metoffice.gov.uk', port=80): Max retries exceeded with url: /public/data/val/wxfcs/all/json/sitelist/?key=fd532e24-e590-45f9-9dd3-68504ba4e317 (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x73f43fb0>: Failed to establish a new connection: [Errno -3] Try again',))
    return fut.result()
  File "/usr/lib/python3.6/site-packages/homeassistant/components/weather/metoffice.py", line 43, in setup_platform
requests.exceptions.ConnectionError: HTTPConnectionPool(host='datapoint.metoffice.gov.uk', port=80): Max retries exceeded with url: /public/data/val/wxfcs/all/json/sitelist/?key=fd532e24-e590-45f9-9dd3-68504ba4e317 (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x73f43fb0>: Failed to establish a new connection: [Errno -3] Try again',))
2017-12-05 20:12:37 ERROR (SyncWorker_7) [yahooweather] No woid is received!
2017-12-05 20:12:38 WARNING (SyncWorker_7) [homeassistant.components.weather.yweather] Can't retrieve WOEID from Yahoo!
2017-12-05 20:12:40 ERROR (MainThread) [homeassistant.components.notify] Error setting up platform pushbullet
    chunked=chunked)
    conn.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x73fdde70>: Failed to establish a new connection: [Errno -3] Try again
    timeout=timeout
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='api.pushbullet.com', port=443): Max retries exceeded with url: /v2/devices (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x73fdde70>: Failed to establish a new connection: [Errno -3] Try again',))
  File "/usr/lib/python3.6/site-packages/homeassistant/components/notify/__init__.py", line 101, in async_setup_platform
    platform.get_service, hass, p_config, discovery_info)
    future.result()
  File "/usr/lib/python3.6/site-packages/homeassistant/components/notify/pushbullet.py", line 38, in get_service
    pushbullet = PushBullet(config[CONF_API_KEY])
  File "/usr/lib/python3.6/site-packages/pushbullet/pushbullet.py", line 43, in __init__
    self.refresh()
  File "/usr/lib/python3.6/site-packages/pushbullet/pushbullet.py", line 381, in refresh
    self._load_devices()
  File "/usr/lib/python3.6/site-packages/pushbullet/pushbullet.py", line 78, in _load_devices
    resp_dict = self._get_data(self.DEVICES_URL)
  File "/usr/lib/python3.6/site-packages/pushbullet/pushbullet.py", line 64, in _get_data
    resp = self._session.get(url)
  File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 521, in get
    return self.request('GET', url, **kwargs)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='api.pushbullet.com', port=443): Max retries exceeded with url: /v2/devices (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x73fdde70>: Failed to establish a new connection: [Errno -3] Try again',))
2017-12-05 20:13:14 WARNING (MainThread) [homeassistant.components.media_player] Setup of platform plex is taking over 10 seconds.
2017-12-05 20:13:16 WARNING (MainThread) [homeassistant.components.media_player] Setup of platform cast is taking over 10 seconds.
2017-12-05 20:13:16 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform plex
  File "/usr/lib/python3.6/site-packages/urllib3/util/connection.py", line 83, in create_connection
    raise err
  File "/usr/lib/python3.6/site-packages/urllib3/util/connection.py", line 73, in create_connection
    sock.connect(sa)
socket.timeout: timed out
    chunked=chunked)
    self.send(msg)
    self.connect()
  File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 146, in _new_conn
    (self.host, self.timeout))
urllib3.exceptions.ConnectTimeoutError: (<urllib3.connection.HTTPConnection object at 0x73fabd70>, 'Connection to 192.168.0.50 timed out. (connect timeout=30)')
    timeout=timeout
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.0.50', port=32400): Max retries exceeded with url: /?X-Plex-Token=yJEGyXkkvaEHLqqxPVEt (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x73fabd70>, 'Connection to 192.168.0.50 timed out. (connect timeout=30)'))
    return fut.result()
  File "/usr/lib/python3.6/site-packages/homeassistant/components/sensor/plex.py", line 55, in setup_platform
    plex_token)], True)
  File "/usr/lib/python3.6/site-packages/homeassistant/components/sensor/plex.py", line 72, in __init__
    self._server = PlexServer(plex_url, plex_token)
  File "/usr/lib/python3.6/site-packages/plexapi/server.py", line 103, in __init__
    data = self.query(self.key, timeout=timeout)
  File "/usr/lib/python3.6/site-packages/plexapi/server.py", line 341, in query
    response = method(url, headers=headers, timeout=timeout, **kwargs)
  File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 496, in send
    raise ConnectTimeout(e, request=request)
requests.exceptions.ConnectTimeout: HTTPConnectionPool(host='192.168.0.50', port=32400): Max retries exceeded with url: /?X-Plex-Token=yJEGyXkkvaEHLqqxPVEt (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x73fabd70>, 'Connection to 192.168.0.50 timed out. (connect timeout=30)'))```
