How to fix frontend "Legacy" version?
My simple question, what is “Legacy” in Frontend version?
This is on my old phone that I use as a desktop display (Companion app), running Lineage OS 18.1 Android 11.
show image
So I was playing around with the dashboard and noticed that some cards are not showing up as they should, for example the one I am currently trying is the visibility option, which shows a blank section instead of hiding the card and filling in the section.
I have also experienced this before with custom weather cards, etc. where the formatting was not showing up correctly.
show image
Screenshot_20241104-090747_Home_Assistant.pn
Finally, is there a way to prevent this from happening? How do I get rid of this “Legacy” version?
The companion app on Android is relying heavily on the Google Webview component, so make sure to update that one on your phone.
OMG, after checked it, turned out that Webview was not installed, after installing it everything worked fine.
Thank you so much for your help!
Its a google component and Linnage OS is not, so you have to install it manually.
May I know which you’ve installed?
I am also facing legacy frontend, but cannot be fixed by installing android webview 131
ps. my device is Sonoff NSPanel Pro 120
Have you tried updating WebView component?
