How to fix incorrect data?
Hello guys,
I have a relatively common problem, but I wasn’t able to find the solution in the other threads.
My Shelly which measures the production of my solar panel lost power and started again at 0. Unfortunately I also lost the network connection to my shelly for a month.
Additionally I used the provided energy value (in kwh) from my shelly, instead of creating a Riemann Sensor.
The last value provided from my Shelly was 389 kwh. The first value after a month is 70 (which is the kwh produced since the blackout).
Yellow= Shelly sensor, Orange= New Riemann Sensor
I could fix the numbers in the database, but that wouldn’t help me because the shelly would always provide “wrong” numbers and I want to use a Riemann-Sensor in the future, which wouldn’t reset on a blackout. I already added it to my dashboard, but it doubles with the “old” shelly production. If I delete the shelly sensor, I loose the data of the last year.
What can I do to fix my statistics? Is there a possibility to transer the data of the shelly from the past year to the Riemann-sensor? Then I could delete the Shelly sensor from the dashboard and have only one sensor in the dashboard…
Kind regards!
