I have a several (light) devices which are connected to HA via zigbee2mqtt. Those devices are currently unavailable because work at the circuit board.
I’m using powercalc to calculate the power and energy usage which seems to be using the latest state, which is ON. Is there a way to manually override the state from ON to OFF or maybe a trick in powercalc to override power usage to 0 based on last seen timestamp?
You need to be aware that Developer Tools only changes what HA perceives to be the state of an entity - it’s mostly used for testing. If there is an actual change - for example if the lights start working briefly then become unavailable again - your setting will be replaced by the real state. Also, it may not survive a restart.
Might be safer to change the Powercalc configuration temporarily.
