How to force filter sensor to recalculate value at specified time interval?
I have modbus senor and filter senor based on modbus senor. however, filter senor updates its value only when modbus senor value actually changes, but if value remains unchanged filter senor is stuck with wrong value :frowning:
How can i avoid such situation?
  - platform: modbus
    scan_interval: 10
    registers:
      - name: komfovent-panel-temperature
        hub: komfovent
        unit_of_measurement: "°C"
        device_class: temperature
        register: 945
        scale: 0.1
        precision: 1
        data_type: int
  - platform: filter
    name: "Valgomojo temperatūra"
    entity_id: "sensor.komfovent_panel_temperature"
    filters:
      - filter: lowpass
        time_constant: 10
        precision: 1
set up an automation to run at the desired time_pattern and have the action be to run the homeassistant.update_entity on that sensor.
