Currently I am developing home automation components with the usage of MQTT. Since a “plug and play” user experience is wanted I am using the MQTT Discovery for the registration of the components to Home Assistant.
However since Home Assistant 2023.8 I have some issues with this set-up. My current UI looks like this. (with the automatic/default dashboard active)
Note: the current temperature is a hardware issue.
The “Server” room should contain the following:
- 1 Light
- 1 Security door (cover) (missing)
- 2 Binary sensors (connected to the cover for remote IO)
The “Toilet” room should contain the following:
- 1 Light (placed in the “Server” room)
- 1 Button
- 1 Window (placed in the “Server” room)
- 1 Occupancy sensor (placed in the “Server” room)
The “Livingroom” room should contain the following:
- 1 Dimable light (named Main)
- 1 Climate
- 2 Binary sensors (connected to the climate for remote IO)
Each of these components has a mqtt path as described in the documentation eg. <discovery_prefix>/<component>/[<node_id>/]<object_id>/config. (see below)
A few of the problematic components are as follows.
The cover (that is missing), has the topic homeassistant/cover/server/security/config and the following JSON
"name": "Security",
"unique_id": "serversecurity",
"object_id": "serversecurity",
"device_class": "Door",
"state_topic": "homeassistant/cover/server/security/state",
"command_topic": "homeassistant/cover/server/security/command",
"availability": {
"topic": "homeassistant/status/server"
"device": {
"identifiers": [
"Server",
"Security"
"manufacturer": "company",
"model": "controller",
"suggested_area": "Server"
My 2 (problematic) lights have the following config
homeassistant/light/toilet/light/config
"name": "Light",
"unique_id": "toiletlight",
"object_id": "toiletlight",
"device_class": "light",
"command_topic": "homeassistant/light/toilet/light/command",
"state_topic": "homeassistant/light/toilet/light/state",
"availability": {
"topic": "homeassistant/status/woonkamer"
"device": {
"identifiers": [
"Toilet",
"Light"
"suggested_area": "Toilet"
homeassistant/light/server/light/config
"name": "Light",
"unique_id": "serverlight",
"object_id": "serverlight",
"command_topic": "homeassistant/light/server/light/command",
"state_topic": "homeassistant/light/server/light/state",
"availability": {
"device": {
"identifiers": [
"Server",
"Light"
What I want to accomplish are the following points.
- A separation between the different components. So that, with the default dashboard active, all the components that are made for a
suggested_areaaso end-up in their respectivesuggested_area. - Get rid of the “Mosquitto broker” part of the name (this should be somewhere in the release notes of 2023.8 but I didn’t have time to implement that (yet)).
- Understand how do the
identifiersportion works.
The issue I am facing is that, although there is a lot of documentation most/all of it is indented for yaml instead of json.
There is 1 more generic question about the availability of the device. This seems defined twice. The 1st is under availability → topic and the 2nd is under availability_topic. What is the correct way to handle this?
Note that the current system (availability → topic) works as intended.
Edit: I should read better. The text under availability_topic reads.
