How to fully remove an integration - can´t get rid of one
Over in HASS OS becomes unresponsive / then almost unusable / and is finally dead - starting every ~ 10 hours after last HA start I started removing integrations by using Settings / Integrations / 3 dots / delete including a HA restart.
But I still see log entries in home-assistant.log which assume the integrations is not really/fully removed yet:
Logger: homeassistant.loader
Source: loader.py:465
First occurred: 23:36:55 (1 occurrences)
Last logged: 23:36:55
You are using a custom integration for trakt which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
First occurred: 16:55:05 (1 occurrences)
Last logged: 16:55:05
In Settings / Info the integration is not listed anymore.
==> So where do those log entries come from?
==> What else to check?
Update: Found a folder “custom_components\trakt” being left. Deleted it, will restart HA and see if log entries will still come up, fingers crossed.
Instead of deleting this young topic I deciced to keep it, maybe someone else will be happy to find it in future.
