I made chicken coop door controller for my parents, and I attempted to make it as self-sufficient as possible as I knew that wifi may be an issue. I put all the automations within esphome instead of HA in the hopes that if it couldn’t phone home it would still work as programmed. I added some API and Wifi timeout settings based on my understanding of what was needed to get it to work without wifi. I thought I had success as the door controller worked as expected when not connected to HA/Esphome/Wifi (in my testing). However, as is the case with most projects, it didn’t go as expected. When I got the door to the coop location and plugged it in I had very strange results, the screen would blink on and off (not programmed) and the buttons wouldn’t work. After a while it began to work, but that is because it connected to wifi, albiet very weakly (~-80db). It stayed connected and worked for a few days and then disconnected. In its disconnected state the door did not work as programmed. I’m wondering if the weird operation is due to it being at the limit of wifi and it’s connecting/disconnecting “quickly”, not allowing it to get to the normal program cycle. Any troubleshooting tips, suggestions or insight would be appreciated. If I can’t get it to work in it’s location with wifi, my last effort will be to disable wifi, however I would like for it to try now and again to connect. Following is the esphome yaml, which is somewhat long, but I assume the relevant area to my issue is in the beginning.
esphome:
friendly_name: coop_controller
on_boot:
then:
# read the RTC time once when the system boots
ds1307.read_time:
rp2040:
board: rpipicow
framework:
# Required until https://github.com/platformio/platform-raspberrypi/pull/36 is merged
platform_version: https://github.com/maxgerhardt/platform-raspberrypi.git
# Enable logging
logger:
#level: INFO
# Enable Home Assistant API
api:
reboot_timeout: 240h
encryption:
key: "secret"
ota:
password: "secret"
wifi:
ssid: !secret wifi_ssid
# Enable fallback hotspot in case wifi connection fails
ap:
ssid: "Coop-Controller Fallback Hotspot"
password: "secret"
reboot_timeout: 24h #default is 15min
i2c:
sda: GPIO20
scl: GPIO21
scan: true
time:
- platform: ds1307
i2c_id: bus_a
address: 0x68
# repeated synchronization is not necessary unless the external RTC
# is much more accurate than the internal clock
update_interval: never
- platform: homeassistant
# instead try to synchronize via network repeatedly ...
on_time_sync:
then:
# ... and update the RTC when the synchronization was successful
ds1307.write_time:
font:
- file: "fonts/roboto/Roboto-Regular.ttf"
image:
- file: "open.png"
- file: "closed.png"
- file: "opening.png"
- file: "closing.png"
display:
- platform: ssd1306_i2c
i2c_id: bus_a
model: "SSD1306 128x64"
address: 0x3C
on_page_change:
- if:
condition:
display.is_displaying_page: page1
then:
sensor.template.publish:
state: 1
- if:
condition:
display.is_displaying_page: page2
then:
state: 2
- if:
condition:
display.is_displaying_page: page3
then:
state: 3
- if:
condition:
display.is_displaying_page: page4
then:
state: 4
- if:
condition:
display.is_displaying_page: page5
then:
state: 5
- if:
condition:
display.is_displaying_page: page6
then:
state: 6
pages:
- id: page1
lambda: |-
it.image(0, 0, id(open_image));
- id: page2
lambda: |-
it.image(0, 0, id(closed_image));
- id: page3
lambda: |-
it.image(0, 0, id(opening_image));
- id: page4
lambda: |-
it.image(0, 0, id(closing_image));
- id: page5
lambda: |-
it.print(0, 0, id(font1), "Time:");
it.strftime(32, 0, id(font1), "%H:%M", id(esptime).now());
it.printf(128, 0, id(font1), TextAlign::TOP_RIGHT,"Wifi: %.0fdb", id(wifi_signal_db).state);
it.printf(0, 17, id(font1), "Temp: %.1f°F", id(coop_temperature).state);
it.print(0, 33, id(font1), "Open Time: ");
it.printf(128, 33, id(font1), TextAlign::TOP_RIGHT, "%s", id(next_coop_door_open).state.c_str());
it.print(0, 49, id(font1), "Close Time:");
it.printf(128, 49, id(font1), TextAlign::TOP_RIGHT, "%s", id(next_coop_door_close).state.c_str());
- id: page6
lambda: |-
it.print(0, 0, id(font1), "");
dallas:
pin: GPIO22
sun:
latitude: 45° #actual location changed for posting
longitude: -85° #actual location changed for posting
on_sunrise:
- elevation: -2°
then:
- logger.log: Good morning Birds - Open Door!
- cover.open: coop_door
- then:
- logger.log: Hello Sun!
on_sunset:
- then:
- logger.log: Goodbye Sun!
- elevation: -5°
then:
- logger.log: Good Night Birds - Door Close!
- cover.close: coop_door
text_sensor:
- platform: sun
type: sunrise
- platform: sun
type: sunset
- platform: sun
name: Next Coop Door Open
type: sunrise
elevation: -2°
- platform: sun
name: Next Coop Door Close
type: sunset
elevation: -5°
cover:
- platform: endstop
device_class: door
open_action:
- display.page.show: page3
- switch.turn_on: green_led_coop
- switch.turn_off: motor_reverse_pin
- switch.turn_on: motor_forward_pin
open_duration: 10s
open_endstop: coop_upr_limit_switch
close_action:
- display.page.show: page4
- switch.turn_on: motor_reverse_pin
- switch.turn_off: motor_forward_pin
close_duration: 10s
close_endstop: coop_lwr_limit_switch
stop_action:
- switch.turn_off: green_led_coop
- display.page.show: page5
- delay: 10s
- display.page.show: page6
max_duration: 15s
- platform: wifi_signal
name: "WiFi Signal dB"
update_interval: 60s
entity_category: "diagnostic"
- platform: internal_temperature
name: "Internal Temperature"
##Dallas DS18B20
- platform: dallas
address: 0x270217b085efff28
name: "Coop Temperature"
filters:
- lambda: return x * (9.0/5.0) + 32.0;
unit_of_measurement: "°F"
##Rotary Encoder
- platform: rotary_encoder
name: "Coop Motor Encoder"
restore_mode: ALWAYS_ZERO
pin_a:
number: GPIO10
mode:
input: true
pullup: true
pin_b:
number: GPIO9
mode:
input: true
pullup: true
##sun sensor
- platform: sun
name: Sun Elevation
type: elevation
- platform: sun
type: azimuth
switch:
- platform: gpio
pin: GPIO32
on_turn_on:
on_turn_off:
- platform: gpio
pin: GPIO15
- platform: gpio
pin: GPIO12
## Setup for motor control pins
- platform: gpio
pin: GPIO18
- platform: gpio
pin: GPIO19
##following is so HA can manually control the same as physical buttons
name: "Manual Door UP"
turn_on_action:
- script.execute: manual_door_open
turn_off_action:
- script.execute: manual_door_stop
name: "Manual Door Down"
turn_on_action:
- script.execute: manual_door_close
turn_off_action:
binary_sensor:
### setup buttons to control door manually
- platform: gpio
pin:
number: GPIO13
inverted: true
mode:
input: true
pullup: true
name: "Button - Door Down"
filters:
- delayed_on: 200ms
on_press:
- script.execute: manual_door_close_local
on_release:
- platform: gpio
pin:
number: GPIO14
inverted: true
mode:
input: true
pullup: true
name: "Button - Door Up"
filters:
- delayed_on: 200ms
on_press:
- script.execute: manual_door_open_local
on_release:
- platform: gpio
name: "Upr Limit Switch"
pin:
number: GPIO16
inverted: true
mode:
input: true
filters:
- delayed_off: 10ms
on_press:
- switch.turn_on: red_led_coop
- delay: 5s
- switch.turn_off: red_led_coop
- platform: gpio
name: "Lwr Limit Switch"
pin:
number: GPIO17
inverted: true
mode:
input: true
filters:
- delayed_off: 10ms
- delayed_on: 2s #allow for the autolock to engage
on_press:
- delay: 6s
- platform: gpio
name: "Main Door Switch"
device_class: door
pin:
number: GPIO6
inverted: false
mode:
input: true
filters:
- delayed_off: 10ms
on_press:
- delay: 10min
on_release:
- delay: 5min
#Scripts to be called so both physical button and HA can manually control door
#Made separate scripts for physical button vs HA "button" for delays
script:
- id: manual_door_open
mode: restart
then:
- delay: 5s
- delay: 10s
- id: manual_door_close
mode: restart
then:
- delay: 5s
- delay: 10s
- id: manual_door_stop
mode: restart
then:
- delay: 10s
- id: manual_door_open_local
mode: restart
then:
- delay: 15s
- delay: 10s
- id: manual_door_close_local
mode: restart
then:
- delay: 15s
- delay: 10s
