Hey, I have no experience with Node Red. I still have an old Home Wizard hub with several thermometers. I would get these values in a home assistant entity. I’ve gotten to the point where I can get the correct values into the debug node through an http request. Furthermore, I’m stuck getting these values into a homeassistant entity. How can this be achieved?
Try the sensor node, you can turn msg.payload (or whatever else) into a sensor. Check out the docs, they lay it all out pretty well. Let me know if you have questions.
Hi, sorry for the late reply, it worked with the sensor node, thx!
