I have to charts I need to show and one of these should be wider than the other for example one should be twice as wide as usual.
So far I have been able to use 3 as the usual horizontal card offers or only 1 panel card.
I was only able to show the first column of entities wider than the other but only inside 1 column shown in the 2nd column with the sun element.
But regarding the 2 charts following I would like to see that twice as wide than the last one in the 4th column.
My first 2 columns are there to show the history what I have tried and did not work out the way I had wanted it, but the goal is to show 2 of the apex charts and the first one far wider than the 2nd.
Sidebar DOES NOT WORK by simply changing from what to SIDEBAR.
You need to create a new panel and chose sidebar from the beginning.
I have now made a new panel as sidebar and then added a horizontal stack with 2 elements, which had worked, but how do I get an entity or anything in the 3rd column.
My first try with the horizontal stack looks like this
