I have an entity card on a dashboard showing todays values for power, gas and water, by way of Utility Meter helper entities. I would also like to display these values for the day before. What would be the easiest way to accomplish this?
Would using a statistics card be an option?
- type: statistic
entity: sensor.gasmeter_kwh
period:
calendar:
period: day
offset: 0
stat_type: change
- type: statistic
name: Consumption yesterday
period:
calendar:
period: day
offset: -1
stat_type: change
That does work, always good to know of another way to do things.
However I really like the entities card layout better, where I also use the custom lovelace-multiple-entity-row row element to keep it compact. Is there a way to do this with an entity card?
I managed to get this by creating number helper entities and setting these entities with an automation each day at 23:59:50 with the value of the current day entity:
alias: Set daily utility values
description: ""
- platform: time_pattern
hours: "23"
minutes: "59"
seconds: "50"
condition: []
- service: input_number.set_value
entity_id: input_number.electricity_from_grid_yesterday
data_template:
value: "{{ float(states('sensor.electricity_from_grid_today')) }}"
entity_id: input_number.electricity_from_solar_yesterday
data_template:
value: "{{ float(states('sensor.electricity_from_solar_today')) }}"
entity_id: input_number.electricity_to_grid_yesterday
data_template:
value: "{{ float(states('sensor.electricity_to_grid_today')) }}"
entity_id: input_number.water_used_yesterday
data_template:
value: "{{ float(states('sensor.water_used_today')) }}"
entity_id: input_number.gas_used_yesterday
data_template:
value: "{{ float(states('sensor.daily_gas_v2')) }}"
mode: single
Then with the help of the lovelace-multiple-entity-row addon created this card:
