How to get Aqara Radiator E1 to turn on/off switch(heater) when temperature is above/below set temperature
Hello, I’m trying to get the following to work. I have a couple of Aqara Radiator E1’s connected true homekit with HomeAssistant successfully but I would like to be able turn on or off a switch when the temperature is below/above the set temperature. (I know act like a thermostat) so I can only turn on the heater when a radiator needs warm water and turn it off when all the rooms are warm enough
So what i wish i could do is customise the climate.smartradiatordiningroom1_4 and add the heater option heater: switch.viessmann
or create a automatisation that would do the same…
Can anyone help me out with this?
Oke I think I found it.
I made a automation
{{state_attr('climate.smartradiatordiningroom1_4', 'temperature')|float > states('sensor.smartradiatordiningroom1_current_temperature_4')|float}}
alias: Heating-TurnOnOffRequest
description: >-
  Turn viessmann on when a radiator needs heat. Turn it off when all rooms are
  at temperature
  - platform: state
    entity_id:
      - sensor.smartradiatordiningroom1_current_temperature_4
condition: []
  - choose:
      - conditions:
          - condition: or
            conditions:
              - condition: template
                value_template: >-
                alias: Check TempDining1
          - condition: and
            conditions:
                value_template: >-
                  'temperature')|float <=
Still testing it out to find out if I missed something
