Greetings awesome people!
My house has a ventilation system which I’m trying to automate. The ventilation has 3 speeds:
- High
- Medium
- Low
I installed a Shelly double switch to turn on either medium or high. The ventilation is low with both are off.
I have a bunch of sensors setup and I want to have some manual control as well. I used helpers to calculate the desired ventilation speed for each of the following criteria:
- Temperature
- Humidity
- Moisture
- Air quality
- Manual (Countdown timer)
I’m currently writing an automation to control all of this and it was getting kind of big, so I though to myself: can’t I do this easier. The current automation looks like this:
Trigger:
A, B, C, D, E
Action:
Choice: A, B, C, D, E = high
turn on: ventilation-high
turn off: ventilation-medium
Choice: A, B, C, D, E = medium
turn off: ventilation-high
turn on: ventilation-medium
Default:
The thing that came to mind was to to create 5 fan helper entities and put them in a group. Than, all i needed to do wat to set the ventilation to match the state of the group.
Of course I have no idea if this is even possible, let alone how to do this. The best thing I can find is to use the “number” helper (0=low, 1=medium, 2=high) and the “max” helper as a group. I guess it works, but it’s not pretty.
My question is: What is are the possible ways to do this?
I’m interested in multiple options so I can learn the differences and apply the best strategy for future automations which are slightly different.
