How to get gas pulse counter in homeassistant energy dashboard
A while ago I setup a hall sensor on my gas meter and everything was working perfectly, gas usage was showing up in the energy dashboard, however, it corroded and broke - didn’t fix it for a year. But I’ve come around to fixing it using the exact same config but it no longer works. I used to use a utility meter helper but it no longer appears as a selection in the gas consumption
the other sensors listed are old utility meters that have been deleted and removed from the database and configs, no idea why they show up
when setting the entity from esphome it shows an error:
my end goal is to just get the gas usage in the energy dashboard. if anyone has a working config it would be much appreciated, I’ve scoured the internet and none work. I haven’t found that there’s any ghosting with my setup as well.
# settings
esphome:
esp8266:
  board: nodemcuv2
wifi:
  ssid: !secret wifi_ssid
  use_address: 192.168.2.183
  domain: .iot
logger:
api:
  encryption:
    key: !secret api_key
ota:
  password: !secret ota_password
# configuration
binary_sensor:
  - platform: gpio
    pin:
      number: D2
      inverted: true
      mode: INPUT_PULLUP
    internal: true
    on_press:
      then:
        - light.turn_on: status_led
        - delay: 250ms
        - light.turn_off: status_led
light:
  - platform: binary
    output: status_led_output
    internal: true
output:
  - id: status_led_output
    platform: gpio
    pin: GPIO2
    inverted: true
  - platform: pulse_counter
    pin:
      number: D2
      inverted: true
      mode: INPUT_PULLUP
    device_class: gas
    unit_of_measurement: "m³"
    icon: "mdi:fire"
    filters:
      - multiply: 0.01 # 1imp = 0.01m³
Late to the party, but I just stembled upon this.
I have a similar problem, only total_daily_energy can be added in the dashboard – but you can create a total_daily_energy sensor based on your binary sensor maybe.
