Hi.
I have a sensor that is an scale in my daughter bed. This sensor is always off and just turn on once a day, at 3am. Is its possible to get the last valid valie that is bigher than X using script?
I would like to run this script during the day ( when sensor is off) and get the last value, bit not when its smaller than 1kg, for example ( false value).
It is possible? How do i do this?
Tks
this is probably not the most elegant way, but you could create a ‘number’ helper entity and then use an automation to trigger whenever the scale measurement is >1kg to set the value of the number entity to the measured weight
Something like this:
alias: Last_Valid_Weight
description: ""
- platform: state
entity_id: sensor.child_bed_weight
condition:
- condition: numeric_state
above: 1.0
- service: input_number.set_value
value: |
{{states('sensor.child_bed_weight')}}
entity_id: input_number.last_valid_weight
mode: queued
max: 10
