I for the life of me, can’t figure out how to get remote live view working with my HA instance. I’ve seen all the different WebRTC, go2RTC, RSTPtoWebRTSP etc…
Though I haven’t found a single, hey this is what you need, and this is how its done. One install says you can use this or this, that install says you can only use this or that. But nothing is working. Has anyone managed to get the remote viewing working and able to share their setup for it?
What method are you using for remote access to your Home Assistant dashboard(s)?
I just created Onvif cameras (you use whatever is best for your cameras), and put the camera entities in my dashboard. I can open them anywhere using Nabu Casa.
All of the integrations you mention above just speed up loading times. You may not need them.
I just went through and wiped every trace of all the add ons, services etc and did a fresh install. Something in one of those must’ve been causing some buggery, all is now working.
