How to get lowest of three values
I have three DS18B20 temperature sensors, each located on a different side of a cabinet outside. The sun often shines on one or two of the sensors, and I figured the one in the shadow would be correct.
I can do this in home-assistant with a template as simple as: {{ [a,b,c] | min }}. However in esphome the min filter returns the smallest value of a single sensor over a specified period. So how could I get the home-assistant functionality in esphome?
Sort the list and pick the first element?
Not sure how to do it in ESPHome but in HA it would be:
{{ [a,b,c]|sort[0] }}
Thanks, but I found no simple way to do that in esphome.
Looks like a lambda.
Create an additional Template Sensor that reads the states of your three real sensors and returns their minimum value.
You said it much better than me!
No no. The really relevant work was yours. I just filled in some missing words. :hugs:
I’ll give this a try. Thank you!
This worked. Here’s the config that works:
    lambda: |-
      if (id(t1).state < id(t2).state) {
        if (id(t1).state < id(t3).state) {
          return id(t1).state;
        } else {
          return id(t3).state;
      } else {
        if (id(t2).state < id(t3).state) {
          return id(t2).state;
        } else {
Now I appreciate much more how convenient filters in home-assistant are.
Happy to hear!
Two tips:
  1. Using the C++ min function would reduce your whole lambda to one line. Not sure out of the back of my head if you have to prepend with std:: but I think so:
    lambda: |-
      return std::min(id(t1).state, id(t2).state, id(t3).state);
  1. You can use blanks in your names.
    name is the friendly name in HA. If you want to apply an internal name to use in lambdas, use name + id:
    name: "Lowest outside temperature"
Additionally, you can also hide t1, t2 and t3 sensors setting “​internal​: ​true” property if you don’t need them in Home Assistant.
Thanks for the tips!
That one-liner is really nice. Thank you. It works like that with two sensors, but three apparently requires brackets. Is that a list in cpp? So the working code is:
lambda: |-
      return std::min({id(t1).state, id(t2).state, id(t3).state});
Oh yes, you are right.
In C++ multiply values enclosed in curly braces are a way to create a prefilled array.
