Hi vingerha (or anyone else), is this for the current day or the coming 23 hours and 59 minutes?
Sorry, found it… → for the current day ![]()
Current day. And the proper way to actually get it would be to use todays date + 1 day.
template:
- trigger:
- platform: state
entity_id: weather.openweathermap
- platform: homeassistant
event: start
- platform: event
event_type: event_template_reloaded
- service: weather.get_forecasts
type: hourly
response_variable: result
- name: Max Hourly Temperature
unique_id: max_hourly_temperature
device_class: temperature
unit_of_measurement: °F
state: >
{% set midnight = (today_at() + timedelta(days=1)).isoformat() %}
{{ result['weather.openweathermap'].forecast | selectattr('datetime', 'lt', midnight) | map(attribute='temperature') | list | max }}
Hi Petro, thanks for jumping in!
Would you mind explaining briefly why this is the proper way?
TIA
Replacing hours/minutes on a datetime object can lead to unforeseen issues if you don’t have the correct timezone. It’s best to use the template methods that we added to make time calculations easier.
The issue is, most forum posts use old methods which run into issues with timezones, leading to undesired effects.
You should avoid using .replace if you can. You should avoid using as_timestamp if you can.
Both can be supplimented with timedelta which is essentially a duration. YOu can add and subtract them from datetimes. If the datetime has a TZ attached to it, you can assume that it will be the correct time in your TZ regardless what TZ the datetime is in.
I tried this and it shows UndefinedError: ‘result’ is undefined. Everything else seems to be ok in there. Not sure what it doesn’t like. I can call the service manually on the service tab just fine.
You have to configure that entire chunk of code in your configuration file, not in a UI template sensor.
Petro,
Thanx for your help!
Did you get it working?
Hi, For me , the states always remain ‘unknown’
Hello everybody!
Great job here, it’s working fine for me.
But I would like to ask how to get the hour of the max temperature of the day, instead of the temperature value itself?
I’m creating an automation to notify me when there is the highest temp outside so I have to open the windows to air out the house… the problem is that for example today the max is 11.1 but right now when it’s supposed to be the highest temperature it’s only 9.x. So It wouldn’t work for me.
Do you have any clue?
Thank you so much for supporting!
How to create a sensor/entity/helper value that is TodaysForcastMaxCelcius, and give it this value, so that I can easily refer to it in all automations?
look up in the post, there is an example by petro
