michel72
(Michel - IngeniousMakers.com)
November 1, 2020, 9:35am
1
I’m stying to get multiple sensors from 1 rest call as the API of my device does not seem to like multiple calls to it’s API
Right now I have configured this:
The rest call http://192.168.207.98/getParameters replies with:
{"type":"parameters","list":[{"vehicleState":2,"evseState":false,"maxCurrent":20,"actualCurrent":18,"actualPower":0,"duration":0,"alwaysActive":false,"lastActionUser":"","lastActionUID":"","energy":0,"mileage":0,"meterReading":0,"currentP1":0,"currentP2":0,"currentP3":0}]}
- platform: rest
name: EVSE Vehicle state
resource: http://192.168.207.98/getParameters
value_template: "{{ value_json.list[0].vehicleState }}"
method: GET
timeout: 30
force_update: true
- platform: rest
value_template: "{{ value_json.list[0].evseState }}"
method: GET
timeout: 30
force_update: true
- platform: rest
name: EVSE Actual current
value_template: "{{ value_json.list[0].actualCurrent }}"
unit_of_measurement: "A"
method: GET
timeout: 30
force_update: true
How could I combine those 3 (or preferably all parameters) into one call?
You can use json_attributes to add other values to attributes in one sensor and then use template sensors for them.
michel72
November 1, 2020, 10:19am
3
Thanks, I found this in another topic, and tried to get it to work for my specific use case, but sofar no luck. Do you have an example for my sensors maybe?
- platform: rest
resource: http://10.161.0.130:2001/sensors
json_attributes:
- temperature
- humidity
- battery
- timestamp
sensors:
temperature:
value_template: '{{state.sensor.csensor.bedroom1.attributes["temperature"]}}'
tom_l
November 1, 2020, 10:32am
4
Specify a json attributes path.
- platform: rest
json_attributes_path: $.list[0]
json_attributes:
- currentP1
- currentP2
- currentP3
- etc...
michel72
November 1, 2020, 10:43am
5
Thank you. That was it:
- platform: rest
value_template: 'OK'
json_attributes:
- vehicleState
- evseState
- maxCurrent
- actualCurrent
- actualPower
- duration
- alwaysActive
- lastActionUser
- lastActionUID
- energy
- mileage
- meterReading
- currentP1
- currentP2
- currentP3
sensors:
evse_vehiclestate:
value_template: "{{ state_attr('sensor.evse', 'vehicleState') }}"
stanekl
(Lukas Stanek)
May 3, 2022, 5:51pm
6
I am trying to read multiple sensors for 1 rest call. It works when I do one rest call to get one sensor via value_json.list[28]. How could I make more sensors it they only differ by number in [ ]?
Thank you for your help
tom_l
May 3, 2022, 10:59pm
7
Use the new rest integration.
rest:
- authentication: basic
username: "admin"
password: "password"
scan_interval: 60
resource: http://192.168.1.12/status.xml
- name: "Sensor 1"
value_template: "{{ value_json.list[28] }}"
- name: "Sensor 2"
value_template: "{{ value_json.list[29] }}"
- name: "Sensor 3"
value_template: "{{ value_json.list[30] }}"
etc...
For anyone looking here’s my setup for the following json response:
"bedroom_shades": {
"state": 0,
"position": 0,
"tilt_position": 0
"kitchen_door_blinds": {
"state": 0,
"position": 100,
"tilt_position": 0.0
"bedroom_blinds": {
"state": 0,
"position": 0,
"tilt_position": 100.0
"living_room_door_blinds": {
"state": 0,
"position": 0,
"tilt_position": 64.44444
The sensor configuration is as follows:
rest:
- resource: http://192.168.0.123/getState
scan_interval: 30
method: GET
verify_ssl: false
headers:
accept: "application/json"
content-type: "application/json"
payload: '{ "type": "get" }'
- name: "bedroom_blinds"
value_template: "OK"
json_attributes_path: "$.['bedroom_blinds']"
json_attributes:
- position
- state
- tilt_position
- name: "bedroom_shades"
json_attributes_path: "$.['bedroom_shades']"
json_attributes:
- position
- state
- tilt_position
- name: "kitchen_door_blinds"
json_attributes_path: "$.['kitchen_door_blinds']"
json_attributes:
- position
- state
- tilt_position
- name: "living_room_door_blinds"
json_attributes_path: "$.['living_room_door_blinds']"
json_attributes:
- position
- state
- tilt_position
And I can see correct data in Developer tools
tom_l
July 26, 2023, 10:07am
9
You should use the value_template for the state, rather than just printing the text “OK” no matter wat at.
