It doesn’t happen often, but occasionally I miss a change to a service call in HA after an update that breaks the call. I don’t notice it until I see the automation not work or see the node has a failed status. I was wondering if there was someway to get notified when an API Error occurs during a service call so that I can fix it right away.
I looked through the documentation and didn’t see any obvious way to do this. There doesn’t appear to be a log file either and the error doesn’t show up in the HA logs. Any assistance would be appreciated!
Thanks, that’s not a node I’ve read about before. Even if I have to copy / paste the catch + service call nodes for the notification to each tab that wouldn’t be too cumbersome and achieve the goal.
