ktos799
(Ktos799)
1
Hello
How to get the index of a sequence and use it in a template?
alias: My script
sequence:
- action: notify.persistent_notification
metadata: {}
message: "index: {{?}}"
metadata: {}
metadata: {}
AFAIK, that’s not available. What are you trying to do?
ktos799
(Ktos799)
3
Script that runs 20 other scripts and field with which script to start with.
example:
alias: My script
sequence:
{# if start_with = 1 then
- action: script.my_script
metadata: {}
data: {}
{# if start_with = 2 then
metadata: {}
data: {}
{# if start_with = 3 then
metadata: {}
data: {}
fields:
start with:
selector:
number:
min: 1
max: 100
I could use variables and increments, but after changing the position of the scripts in the main script I have to rewrite everything.
Do the scripts’ entity IDs or friendly names contain their “index”?
If so, you could do a Repeat for each by templating the for_each
- repeat:
for_each: "{{ range(start_with: 21) | list }}"
sequence:
- action: script.my_script_{{repeat.item}}
metadata: {}
data: {}
Or, if not, move the list of scripts in the order you want into a variable then do something like:
- variables:
script_list:
- script.my_script_a
- script.my_script_b
- script.my_script_c
- script.my_script_d
- repeat:
for_each: "{{ script_list[start_with-1:] }}"
sequence:
- action: "{{repeat.item}}"
metadata: {}
data: {}
ktos799
(Ktos799)
5
No. The same script may be used multiple times or not used
I think it would be best to create helper, iterate in scripts and if ‘index’ < ‘counter.start_witch’ then stop sequence.
