Hello there!
I have a TP-Link switch and I enabled SNMP v3 with password on it, but I have no idea how to get what’s called OID.
I’d like to get cpu, mem and bandwidth usage from it and maybe the ability to activate/deactivate ports on it (and maybe bandwidth per port?).
Or maybe I understood that wrong and it’s not possible?
Would that be possible? How I can I get the OID for those? I think the rest of the HA integration will be easy (I hope), I just have no idea how to get those freaking numbers XD
Thinks folks!
Thanks! After reading that I investigated and was able to get data using snmpwalk on my computer!
Port status, cpu and mem. I now need to investigate how I can get port utilization like the tp-link interface does.
It seems that HA doesn’t retrieve the data. I have no error from docker nor from HA. Here is my config and below is the command I used to test OIDs on my computer.
I tested using the command snmpwalk -v3 -a SHA -l authNoPriv -u MYUSERNAME -A MYPASSWORD SNMPIP 1.3.6.1.4.1.11863.6.4.1.1.1.1.2
So I’m not sure why I don’t get the cpu data and others.
Second question: I want to monitor 28 ports (mostly for fun). I want to see the status (plugged, unplugged, off), create a switch to control each port and be able to see the traffic from them and the uptime, etc. Is there an easy way or do I need to create 28 sensors + 28 switches and do 28 requests to my switch every x seconds? 1.3.6.1.2.1.2.2.1.8 returns the status of all ethernet ports so it would avoid querying the switch multiple times…
EDIT: After creating a test switch and turning it on, I get reports of the switches, but not the CPU/RAM. So there’s that. Gonna update here once I find why CPU/MEM is not working for my future self.
Wanted to try something similar with SNMP as well and was hoping you had found a solution? There are a lot of old server rack stuff that uses SNMP that would be great to automate
