bogdan.sv
(Bogdan 🌻)
January 11, 2023, 7:52am
1
I’m trying to set up a Vacuum Card . I need to get the relative time of last cleaning. Like last cleaning 1 hour ago. For this I use the sensor sensor.archik_last_clean_end. In another topic , I saw that such a template worked for @Stooovie . My configuration now looks like this
type: custom:vacuum-card
entity: vacuum.archik
actions:
start:
service: vacuum.start
service_data:
entity_id: vacuum.archik
stats:
default:
- entity_id: sensor.archik_last_clean_end
value_template: {{ relative_time(as_datetime(states('sensor.archik_last_clean_end'))) }}
subtitle: Last clean end
However, after saving the card configuration, I get this result
'[object Object]': null
I get an error in the logs
homeassistant.components.websocket_api.http.connection
547406570944] Error handling message: expected str for dictionary value @ data['template']. Got {'[object Object]': None} (invalid_format) from fe80::e4cd:1fe5:c1b9:aa5
Please help to solve this problem
bogdan.sv
(Bogdan 🌻)
January 11, 2023, 3:54pm
2
These options don’t work for me either
value_template:'{{ relative_time(states.sensor.archik_last_clean_end)}}'
http://homeassistant.local:8123/frontend_latest/57a46f81.js:1:0 NS_ERROR_FAILURE:
value_template: "{{(as_timestamp(now())-as_timestamp(states.sensor.archik_last_clean_end)) | int }}"
http://homeassistant.local:8123/frontend_latest/a18df7ad.js:25:12597 TypeError: can’t convert undefined to object
bogdan.sv
(Bogdan 🌻)
January 11, 2023, 6:46pm
3
The template works in the template editor, but not in the vacuum card
bogdan.sv
(Bogdan 🌻)
January 12, 2023, 9:24am
4
I managed to set up the correct configuration. It is worth noting that changes to the card occurred only after saving.
actions:
start:
service_data:
stats:
default:
value_template: '{{ relative_time(as_datetime(states(''sensor.archik_last_clean_end''))) }}'
