How to get the value from Node-red HomeSeer device to update before sending it to Influxdb
I created a flow (just starting with Node-red) which should sent some device data to the influx-db. Helping me to create a chart to monitor the device values over longer a period.
This is what I have now. But I only get one value (after deploy or opening node-red) update from the HomeSeer Device. How to make the HomeSeer device publishing on going data (update)?
[{"id":"9cf79844.811da8","type":"tab","label":"InfluxDB","disabled":false,"info":""},{"id":"fa7003.cd5af","type":"influxdb out","z":"9cf79844.811da8","influxdb":"c3d410e56f3ec069","name":"","measurement":"watt","precision":"m","retentionPolicy":"","database":"","retentionPolicyV18Flux":"","org":"","bucket":"","x":1000,"y":200,"wires":[]},{"id":"22509df2.cebb8a","type":"debug","z":"9cf79844.811da8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":570,"y":100,"wires":[]},{"id":"b6a82334.e36db","type":"debug","z":"9cf79844.811da8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":990,"y":280,"wires":[]},{"id":"66ac6f36e10b329d","type":"hs-device","z":"9cf79844.811da8","name":"Boven Badkamer Thermostat Watts 4","device":"766","server":"367ff7807724edc9","feature":"775","reportonstartup":true,"x":210,"y":160,"wires":[["22509df2.cebb8a","83eefe53126f954b"]]},{"id":"41fc126c7222a379","type":"function","z":"9cf79844.811da8","name":"get value from thermostat","func":"// msg.topic = 'currentTemp';\nmsg.payload = msg.payload.value;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":650,"y":360,"wires":[["fa7003.cd5af","b6a82334.e36db"]]},{"id":"83eefe53126f954b","type":"json","z":"9cf79844.811da8","name":"","property":"payload","action":"obj","pretty":false,"x":490,"y":200,"wires":[["41fc126c7222a379"]]},{"id":"c3d410e56f3ec069","type":"influxdb","hostname":"192.168.0.33","port":"8086","protocol":"http","database":"homeseer_data","name":"homeseer_data","usetls":false,"tls":"","influxdbVersion":"1.x","url":"http://localhost:8086","rejectUnauthorized":true},{"id":"367ff7807724edc9","type":"hs-server","name":"HomeSeer Server","host":"192.168.0.39","port":"80"}]
