How to get timers real remaining time?
Hey everybody!
Trying to get seconds from timer in automation (9 seconds on the screenshot):
I thought {{state_attr('timer.killer', 'remaining')}} would help, but it did not. ‘Remainig’ updates only if timer is paused. And I am trying to get ‘live’ time. How can I achieve that?
How about {{ states('timer.killer') }}
Interesting naming…
Nope, thats not gonna work
Making smth like countdown with tts for security system (siren + countdown)
I want to send tts every 10 seconds so it would be like:
“You will be destroyed in ** seconds”
This could be more easily done with the repeat action and delay, check 0.113 release notes.
I am using repeat, but I don’t really want to hardcode time in automation. It seems like timer would be perfect here. I thought that there is a simple way to get live time
??? The time is still hardcoded with a timer, right?
I mean that with timer I will get real time with correct intervals. So there will not be any situation when time is counted incorrectly
Can I be precise if I use delays?
And by the way, how do you mean to do it with repeat?
If I use repeat - I should have a variable for seconds left
I just linked to an exact answer to your question. That you probably should have found by searching yourself. Took me all of 15 seconds.
thank you for your time, sorry for spamming
