Why I dont have to-do list on sidebar? Is it some addon I need to install?
Have you updated to the correct version? It was just introduced in 2023.11
I have installed all available updates:
Core 2023.11.2
Supervisor 2023.11.0
Operating System 11.1
Frontend 20231030.2
Should I have it by default or should I install something or change some setup for side bar?
You have to go to settings → Devices & services → Add Integration → search for Todo
It also pops up if you install an integration that uses a ToDo entity. The new beta of the HACS O365 integration is switching to a ToDo entity for Microsoft ToDo and installing it added the UI to the sidebar.
Thank you for both
