Just a note, not the least to myself for future reference on how to move from the HA CLI to OS level in terminal.
I had issues login root from home assistant CLI. Login incorrect was all I got all the time, even though I used the Advanced SSH & Web Terminal and had the Protection Mode turned off.
What did the trick for me was to use this in HA CLI
nsenter -t 1 -m -u -i -n -p -- sh
This got me out of the HA container and in to the OS level.
This was needed in my case in order to update my RaspBee device, works the same for the ConBee device too.
Could you reformat this using the quote symbol in the editor? The last part looks like a long dash followed by āshā but not sure⦠but if one did a copy-n-paste into the command line shell, it fails.
I think you mean to say that the command is nsenter -t 1 -m -u -i -n -p sh
OK, yep that seems to work.
Let me ask separately, I myself havenāt figure out what this did to help you.
For example, there is still no access to say /lib/firmware/ with all the deviceās firmware files that the HAOS kernel uses. So what were you able to do after using this command that you could not do before?
