I have integrated my Fibaro Homecenter 2 into Home Assistant and it is working great.
When I change a node name in HC2 it doesn’t update HA. Is that behavior correct?
Did you figure this out? I get the same issue.
I’ve move/rename devices with Fibaro but they stay the same in HA.
+1 - any fix for this? Particulalry annoying if you chnage from an applicance to a light.
