How to get user codes (pin codes) from ZWave dead bolt from Zwave JS
Pretty new to Home Assistant and working my way through the learning curve. I’ve got most everything working including sending pin codes (user codes) from Node-Red into a specific slot in my Z-Wave lock. All is good. The last step is to confirm that the code actually got to the lock successfully. I thought I would query the lock and the specific slot and get the return value and compare with what I sent.
That’s where I’m stuck. I can query the lock and see the pin code in slot 50 as an example when I look at the Events in the ZWave JS UI interface, but for the life of me I can’t figure out how to read that event into Node-Red so that I can parse the parameter that I need.
This is what I see in HA:
I’ve tried zwave_js_notification and zwave_js_value_notification in the events nodes but don’t see it there. Is there a way to get it from the integration? Is there a better way to do this?
Thanks in advance.
Patrick
You need to use the Value Change of a Z-Wave JS Value event which is available when you select a Z-Wave Device.
Thanks for your reply Cornell. Is that something that exists in Node-Red or in HA? I did some searches but I’m afraid I need a bit more guidance. If you wouldn’t mind providing some additional detail I’d appreciate it.
Thank you.
The value change on a z-wave value exists in both node-red and in HA. I have very limited experience with node red but a lot of the Z-Wave stuff is similar.
To access it in HA you select device as your trigger type then select a Z-Wave Device from the list shown. Then select value change on a z-wave js value from the trigger list.
To access it in node-red you select the device node then select a Z-Wave device from the list. Then select value change on a z-wave js value from the trigger list.
