I’ve got a bunch of Integrals and Utility helpers that I made in the GUI (see the attached image). How can I pull out or edit the YAML code for them?
HA: 2024.11.3, Frontend: 20241106.2
AFAIK you can’t.
all UI stuff is stored as json in the .storage folder.
the dashboard and automation, etc conversion to yaml is done in the frontend via special code that isn’t available for other things that are configured via the UI.
If you need the yaml you’ll either have to pull the json from the .storage folder and manually convert it to yaml or just build the helpers manually in the first place via yaml and forego the UI.
