Hi! I want to disable motion detection in the guest bedroom when a guest is staying over.
I have a way to disable motion detectors, but they all come back on at 5am.
Rather than exclude this one set of motion detectors, I thought of adding an override:
- A toggle that when enabled would take precedence for controlling motion detectors. This is very manual, and I’ve already decided against t.
- An
input.datetime
that gives the “stays until” date. Then my automation needs a template to comparetoday > that date
. To allow my wife access to this helper, I can add it to the dashboard. - A calendar connection such that any “Guest Staying Over” calendar event triggers this mode. This way, I can also configure a start date to plan ahead, and my wife could also add it to our calendar, so it’s not just me.
#2 looks funky in the dashboard
Not a great dashboard experience because it requires 1 extra click:
Thinking about it, I can always add a start date input. I just can’t have more than one at a time which… That’s probably fine as we rarely have guests over, and definitely not multiple lined up at a time.
#3 issues
Using the calendar depends on adding a specific calendar all-day event with a specific name, so Home Assistant knows what to look for.
It’s something you have to remember how to do, and it’s not part of Home Assistant, so that means it’ll break if Internet troubles occur. I don’t like using a 3rd party system for this kinda stuff.
