I am trying to handle telegram commands with an event trigger automation. However, it apparently works very iffily. If I do this:
- trigger:
platform: event
event_type: telegram_command
service: telegram_bot.send_message
message: something {{ trigger.event.data.command }}
I expect the command name to be answered back to me via Telegram. Instead, I get the message text literally. However, if I try this:
- trigger:
platform: event
message: {{ trigger.event.data.command }}
So I just put the template in the message without any prefix, then I get an error message that my configuration is invalid.
Error loading /home/homeassistant/.homeassistant/configuration.yaml: invalid key: "OrderedDict([('trigger.event.data.command', None)])"
in "/home/homeassistant/.homeassistant/automations.yaml", line 232, column 0
How do I access the event data from the automation?
