How to have a condition with zone.home
Hello I want only to run this automation when there are 0 people at home (zone.home). This is my automation
alias: Lampenaanuitalsniemandthuisis
description: ""
 - platform: sun
   event: sunset
   offset: "-00:15:00"
 - platform: sun
   event: sunset
   offset: "03:02:00"
condition:
 - condition: numeric_state
   entity_id: zone.home
   attribute: persons
   above: -1
   below: 1
 - if:
     - condition: time
       after: "20:00:00"
       before: "22:00:00"
   then:
     - service: scene.turn_on
         entity_id: scene.kamer_lan_gewoon
       metadata: {}
         entity_id: scene.kamer_binh_normaal_alle
       metadata: {}
     - type: turn_on
       device_id: 3d8f7a511f8ace443784b34f00f7ad03
       entity_id: light.lamp_schouw
       domain: light
     - type: turn_on
       device_id: 4e4ae64deecf42d31ec314aa2410641b
       entity_id: light.lamp_bank
       domain: light
   else:
         entity_id: scene.lampen_binh_uit
       metadata: {}
         entity_id: scene.kamer_lan_uit
       metadata: {}
     - type: turn_off
       domain: light
     - type: turn_off
       domain: light
mode: single
But with this automation its always running also when there are people at home. Which condition do I need to use?
You have set it to use the attribute persons which will not work with a Numeric state condition. The attribute field is optional and should be left blank when you are basing your condition (or trigger) off the State of the entity.
To simplify your condition, just use a State condition looking for 0:
 - condition: state
   state: 0
