How to have input boolean icon change color when switched?
Hey all, I have a hopefully simple question. When I toggle a switch in the dashboard, the icon changes color to show that it’s in the “on” state. However when I toggle an input boolean the icon doesn’t change:
There isn’t really anything to the config, just:
input_boolean:
  holiday_mode:
    name: Toggle for Holiday Mode
    icon: mdi:pine-tree
So is it possible to have the icon change color when the toggle is on?
Did you ever find a solution for this?
I have a Meross wifi plug that isn’t natively supported, so I’m using IFTTT and an input_boolean to toggle it on and off, but I’d like to be able to have the icon associated with it in the UI to change like the other light bulbs.
Nope. :frowning:
You would think there was an easy way to do that. I started looking into light templates and it all got too complicated for me. I’ll just leave it as is for now.
I would have thought so too. But I never came up with anything useful and it wasn’t that big of a deal to pursue any further. Seems like it should be something stupid simple, but I’ve learned to pick my battles. :stuck_out_tongue:
I got it to work!
I’m using a Template Switch and scripts to turn the plug on and off.
platform: template
switches:
  meross_plug:
    value_template: '{{ states.input_boolean.meross_plug.state }}'
    friendly_name: 'Meross Plug'
    turn_on:
      service: script.ifttt_meross_plug_on
    turn_off:
      service: script.ifttt_meross_plug_off
<< scripts.yaml >>
  ifttt_meross_plug_on:
    sequence:
      - service: ifttt.trigger
        data_template: {"event":"Plug1_On"}
      - service: homeassistant.turn_on
        entity_id: input_boolean.meross_plug
  ifttt_meross_plug_off:
    sequence:
        data_template: {"event":"Plug1_Off"}
      - service: homeassistant.turn_off
Huh, that does in-fact work. If I could like it more than once I would. Thanks for figuring it out, cheers!
Hello, I also have input_boolean
But I did not understand in the script how it changes the color of the icon …
I wanted to change the color … I tried to set the example, but I think I made a mistake.
I also use ifftt and sonoff
In my opinion you don´t need the script.
Try this modified for your needs:
  switches:
    whatever:
      value_template: '{{ states.input_boolean.whatever.state }}'
      friendly_name: 'Whatever'
      turn_on:
          data_template: {"event":"Whatever_On"}
          entity_id: input_boolean.whatever
       turn_off:
          data_template: {"event":"Whatever_Off"}
The homeassistant.turn_on and turn_off also changes the color of the icon.
I tried to make this example. to understand switches, but I have an error. see the log
starting version 3.2.4
Testing configuration at /config
Failed config
  switch.template:
    - Invalid config for [switch.template]: expected a dictionary for dictionary value @ data['switches']. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/switch.template/
      switches: None
      whatever: [source /config/configuration.yaml:96]
        friendly_name: Whatever
        turn_off: [source /config/configuration.yaml:104]
          - data_template: [source /config/configuration.yaml:105]
              event: Whatever_Off
          - entity_id: input_boolean.whatever
        turn_on: [source /config/configuration.yaml:99]
          - data_template: [source /config/configuration.yaml:100]
              event: Whatever_On
        value_template: {{ states.input_boolean.whatever.state }}
Successful config (partial)
  switch.template:
What’s not being explained to you is that this is a switch template, not an input boolean. You’ll have to swap your input boolean control for a switch template:
yes, and those yellow switches are the default color switches , like using the device_class on (binary) sensors.
you can however change to any color you like using customization:
homeassistant:
  customize:
    input_boolean.notify_notify:
      templates:
        icon: >
          if (state === 'on') return 'mdi:bell';
          return 'mdi:bell-off';
        icon_color: >
          if (state === 'on') return 'rgb(251, 210, 41)';
          return 'rgb(54, 95, 140)';
@Mariusthvdb’s solution seems easier than a template switch if you are using an input_boolean. Just my opinion @iorifly
admitted, the difference between an inout-boolean and a template switch like this isnt always as clear as one would want. When to use which, im not 100% certain yet, and have them mixed here and there.
Customizing these switches btw is just as easy :wink:
switch.mode_developer:
  templates:
    icon: >
      if (state === 'on') return 'mdi:remote-desktop';
      return 'mdi:briefcase';
    icon_color: >
switch:
    switches:
      mode_developer:
        friendly_name: Developer mode switch
        value_template: >
          {{ is_state('input_select.mode', 'Developer') }}
        turn_on:
          - service: script.mode_developer_direct
            entity_id: input_boolean.notify_developing
        turn_off:
          - service: script.mode_normal_direct
I have the switch. But when on, it does not allow. Back to off. And it does not change the color …
    switches:
      skylight:
        value_template: "{{ is_state('sensor.skylight', 'on') }}"
        turn_on:
          service: switch.turn_on
            entity_id: switch.skylight_open
        turn_off:
            entity_id: switch.skylight_close
switch.turn_off …
Sorry. It was not clear to me. Could be more specific. Thanks for your help.
It was this way and this is giving error:
    switches:
      skylight:
        switch.turn_on:
        switch.turn_off:
Log:
Invalid config for [switch.template]: [switch.turn_on] is an invalid option for [switch.template]. Check: switch.template->switches->skylight->switch.turn_on. (See ?, line ?). Please check the docs at Template Switch - Home Assistant
The example on the docs page uses another entity for Off than for On. You want the same switch to be either turned On or Off.
It all depends on the entities and states you want them to have.
as an example please see this:
sw_tester_template:
  friendly_name: "Tester"
  value_template: "{{ is_state('binary_sensor.tester_state_bin', 'on') }}"
    #      value_template: "{{ is_state('sensor.tester_state', 'on') }}"
  turn_on:
      entity_id: switch.sw_tester_cl
  turn_off:
    service: switch.turn_off
switch.turn_on is of course a perfectly valid option, you must use the service: before it though … and you don’t have a value_template set yet? (in the last bit of code you show)
I’m actually testing to see if it changes color when I call. However, when I turn it does not stay on … Then it goes back to off.
If possible, send me a complete example. I’ll put it in my HA to see if I understand what you’re trying to explain … Putting fragments of code, it gets more confusing.
