I want to use a script to wrap a light.turn_on
service call with a bunch of default params prepopulated so I don’t have to pass the same thing everywhere (e.g defaulting a color). I use both forms of entity_id: <string>
and entity_id: <list>
across my config and am wondering the best way to have the script recognize either format in the data_template
section?
you should be able to put the entity_ids into the template results as a comma separated list:
data_template: >
{% if something %}
entity_id.a, entity_id.b, entity_id.c
{% endif %}
Yeah I was trying to avoid changing all my entity_id
fields and actually prefer the yaml list format, but this is a decent alternative. Thanks!
Ended up just using a python_script
instead; works great and much more concise!
