How to hide a sensor defined in ESPHome for HomeAssistant
I defined something like that:
  - platform: homeassistant
    name: "ESP Wohn Beamer Leistung"
    entity_id: sensor.wohn_beamer_leistung
This gets me a sensor value from HomeAssistant into ESPHome. I need this value for an automation in ESPHome.
No this entity is mirrored back into HomeAssistant also. Which is useless.
Can I disable that on the ESPHome configuration side?
Thanks. Cu!
    internal: true  ##  <------ Add this ##
The other way is to only specify an id without a name.
