I’ve noticed that since I’ve started using the cloud service that it now shows entries in logbook for alexa. I don’t have “included” and previously it was not showing up. What do I need to add to exclude these entries from logbook and or history.
I dont really need to know if alexa turned on a light , just seeing the light turned on is fine for me
I have Alexa working via the paid cloud service. And homekit just via configuration.yaml.
The Alexa entries started showing up in logbook within the past month or so. Pretty sure it was not there before. I just want them not to show up. I have my logbook includes listed for the devices I want to log, and alexa/cloud and homekit are not listed.
Well,
It’s not the end of the world, just annoying to see a line for “alexa, turned off your light”, followed by a line “light was turned off”. Who care’s if Alexa turned it off. At least I dont care to know if it was turned off with alexa, or HA app, or manually.
I’ll check when I get a chance. For the logbook entry for alexa though, it just brings up the light or switch, etc that was controlled by Alexa. Looks exactly the same as the entry above it that shows the light/switch, etc was turned on/off.
Good things to look for though, will defintiely report back when I have a chance to look
Use the recorder integration to exclude the alexa_smart_home event type in your configuration file. Alexa events will never get recorded and never show up in the logbook. You can also view the database that recorder generates for other event types you might want removed.
