I’ve been searching high and lows for ways to hide each individual entity but I don’t have any luck. Ideally, I would like to control all the entities with one Header Toggle Button and in place of each entity toggle show the status like “on/off”. One way to do this is put them into groups.yaml but the group parameters don’t even have an option to “hide” or change the look of the toggle button for each entity.
I also tried setting in customize.yaml the following but the toggle switch that for that entity did not hide.
I think OP wants to hide the control for individual entities and only show the card toggle. Not sure HA allows this, but you could workaround by creating template sensors for each entity and show them in card instead. Then place a group entity at top with an exposed control.
I might be late to the party, but I have just faced the same problem, and I couldn’t find this solution on the forums. Fortunately I could solve the issue by specifying simple-entity as the type of the entity object (I found this option here:
For completion: If you don’t want the “on/off” text (instead of the toggle) either and don’t want to fuff around with making dummy binary sensors just for that, use cardmod to hide the on/off text via css. Add this in the particular entity row:
