I have some scripts on my router that send some status data via MQTT to Home Assistant. The scripts support discovery messages and use object_ids and also unique_ids. This works so far.
Now I want to be able to request the state of some of those entities as they may have changed from within Home Assistant. Therefore I have a twig template to request the entities of the device via curl. This also works.
But only as long as the object_id hasn’t been changed. As soon as the user changed the object_id, I cannot safely identify the read data any more. I can still retrieve information about all entities, but I cannot safely match the read data with the according data on the router any more.
Indeed, that was the way I want to go now. Maybe it could make sense to expose the unique_id in future releases so that one can avoid building this manually.
I’m using a setup that may be a bit special: I’m creating the device and its entities via MQTT device discovery once. Every now and then I query the formerly created switches using curl by sending a template script.
That seemed simpler to me than subscribing to a topic via MQTT but I need a possibility to safely identify and map the entities with my topics. The problem is that I can set the desired object_id via MQTT, but I get no feedback whether it was valid or it already existed and got any suffix. Moreover the user could change the object_id and I would also loose the mapping.
