Hello HA community, maybe it’s a simple question but I’m really having a trouble to see the best way to track it.
I bought 5 temperature sensors (Xiaomi Aqara Smart Home Temperature & Humidity Sensor) and I’m able to synchronize and see their status through my hass.io setup using MQTT.
After synchronizing them all together, I’m not able to properly identify which sensor is which. What is your best practice to keep a track of each individual sensor? Should I sharpie* them with a serial number and write somewhere?
For my smart light bulbs, I connect one at a time and use a pencil to mark the entity_id on the housing. I use pencil in case I need to change it later. The bulbs are fixed in position so accidentally erasing the id through handling is not an issue as might be the case with your sensors.
You could use a permanent marker inside the battery cover if you don’t want it visible from the outside.
Once you know which one it is, give it a friendly name (LivingRoomTemperature, Outdoor, …) in the z2m config and it will show up with that name in HA. That works, if you don’t move the sensors around.
Still learning this part to give it a friendly name.
Anyway I’m doing now step by step instead of setting everything together while also giving them some serial number to easily track. I don’t have any plans to move them but we never know the future
