For automations i am using node red and all flows are blocked.
All automation created with the HA automation feature have been disabled.
For the most part i do not have to worry about it. It runs as it should.
I have a pellet stove and a fan that in the automations (or flows) started at a specific time in the morning, checks if i am home and if the temperature goes below a certain level turns on … simple.
During the winter no issues
Now that the temps are above the threshold the stove and fan still turns on at the specific time.
I checked the debug nodes and the flow in my node red flow for climate control and no activity is shown
I verified if my automation in HA “automation module” are disabled … they are
Where else can i look to find out what triggers these devices.
I started building the automation using the HA function, and all worked well.
Last summer, i started to learn node red and slowly migrated all my automations (8) to node red.
As i was learning more, I added some complexity to my automation for example verify if i am nome.
All of this could have been done in HA however as i am a visual person I prefer looking at blocks as opposed to words (i’m also dyslexic).
Yes all older automations are disabled .
I tried to check the logs and it shows switch pellet stove on from 7:30 to 9::00 when i turned it off.
I have no scenes , scripts or helper added to my HA
After playing and monitoring this device the issue still remains.
Status
No HA automations are enabled
No activity in Node Red climate flow or any other flows dealing with pellet stove (geofencing)
No scripts are developed or enabled
switch *Fibaro" has no setting to turn on at 7:30
Fibaro switch is always on (as it should be because it waits for HA to be activated)
The logs state: Pellet Stove turned on triggered by service Switch: Turn on
My automation yaml has many instances of switch turn on.
I presume that when i build an automation in HA, HA automatically creates the entries in the automation yaml. Equally when i create flows in Node Red it too generates input in the configuration yaml.
I’m not savvy enough to peruse this yaml and understand what i can delete and or modify.
Therefore If i fiscally delete the HA built automation (as opposed to NR) will this delete the entries in the automation yaml?
After all your help and the assistance given to me by the fibaro group,
I deleted all my automations in home assistant and disabled all the flows in node red
Then I started them up one at the time
I finally found the culprit
What caused this issue was that in the node red flow “call service node”
There is the possibility of adding and defining area, a device and an entity.
In my flow media center control flow i added the fields named area as living room, the device as my amp name and my entity as my amp plug. (This was the only flow with all 3 fields filled in)
I did not considered that the area field was a possible “field” to act upon.
I always considered it as being a generic label… my mistake
Once i realised that the area was not a label i could delete … i did
Furthermore i realised that the are field can be used to trigger multiple devices in the same area to change state …Interesting for my next project (media room)
This will mean that with the activation from a door sensor I can control the lights, the projector, the screen and the climate with one automation (flow) youppi.
Many thanks to you all for your help. patience and guidance
