In Matter (formerly Project CHIP), it is possible to bind two matter deives (i.e, ESP32-H2 with a lighting app (0x0101) and ESP32-H2 with a dimmer switch (0x0104)) via the Linux terminal using the below commands. I need to achieve the same binding via the HA app instead of the Linux terminal. How do we achieve this so that we can communicate between devices and controllers even when the HUB is powered OFF? The same binding was available in the HA system for the Zigbee devices. But this binding was not available for the Matter devices.
I have achieved this from Linux terminal (CHIPTool) using the below commands:
For pairing to Network:
./chip-tool pairing code 1
Providing access control:
./chip-tool accesscontrol write acl ‘[{“fabricIndex”: 1, “privilege”: 5, “authMode”: 2, “subjects”: [1], “targets”: null },{“fabricIndex”: 1, “privilege”: 3, “authMode”: 2, “subjects”: [2], “targets”: null }]’ 1 0
For binding:
./chip-tool binding write binding ‘[{“node”:1, “endpoint”:1, “cluster”:6},{“node”:1, “endpoint”:1, “cluster”:8}]’ 2 1
