evadim
(Vadim Efimov)
June 26, 2021, 4:51pm
1
In recent ESPHome now possible to import states from HA to ESPHome:
Home Assistant Sensor
Home Assistant Text Sensor
But don’t get idea how I can import light on/off state, if it possible at all.
I tried both like this:
text_sensor:
- platform: homeassistant
entity_id: ight.vykliuchatel_v_koridore
but if I toggle light I see nothing in logs.
General idea: my wall switch have status led. I want to set led state depending on light bulb state as it can be turned on from another switch or UI - and in this case have “wrong” color.
myle
(StePhan McKillen (Other kiwi Here))
June 26, 2021, 5:51pm
2
Look at spelling think it should be light.vykli…
XCray
June 26, 2021, 9:53pm
4
I also think it should work as you described. Maybe in a future version.
If don’t, there’s another choice:
create one template binary_sensor pulling the state of the light in ha, and pulling state of the binary _sensor in esphome
evadim
(Vadim Efimov)
June 26, 2021, 9:59pm
5
Oh… funny thing: when I try “sensor” I use correct spelling. And then I somehow copy-paste in wrong way
Now I got state:
[00:45:40][C][homeassistant.text_sensor:022]: Homeassistant Text Sensor 'current_light_state'
[00:45:40][C][homeassistant.text_sensor:023]: Entity ID: 'light.vykliuchatel_v_koridore'
[00:45:40][D][homeassistant.text_sensor:016]: 'light.vykliuchatel_v_koridore': Got state 'off'
[00:45:40][D][text_sensor:015]: 'current_light_state': Sending state 'off'
[00:46:19][D][homeassistant.text_sensor:016]: 'light.vykliuchatel_v_koridore': Got state 'on'
[00:46:19][D][text_sensor:015]: 'current_light_state': Sending state 'on'
[00:46:21][D][homeassistant.text_sensor:016]: 'light.vykliuchatel_v_koridore': Got state 'off'
[00:46:21][D][text_sensor:015]: 'current_light_state': Sending state 'off'
Good day.
I have searched high and low for anything related to this, but can’t seem to get esphome to compile it due to it saying “On/Off” not declared in scope.
Is there any way of using the imported state of a light (On/Off) and use this as a trigger for an automation?
Basically…
on_press:
then:
- if:
condition:
and:
- switch.is_on: ${sen_id}_day_night
- lambda: 'return id(mains_volt).state > 180;'
# use the state of the light in HA eg: off #
then:
- light.turn_off:
- homeassistant.service:
service: light.turn_on
entity_id: light.bathroom_light
- lambda: !lambda |-
id(timer).publish_state(true);
else:
- script.stop: timeout
- if:
condition:
and:
- light.is_off: ${sen_id}_led
- lambda: 'return id(mains_volt).state < 180;'
then:
- light.turn_on:
red: 100%
green: 95%
blue: 90%
else:
evadim
(Vadim Efimov)
August 22, 2023, 8:41am
7
In my opinion better to create new topic with your question.
Anyway, this is what I have after all those years in ESPHome config to automate led depending on entity state imported from HA:
text_sensor:
entity_id: light.liustra_v_koridore_1
on_value:
then:
- if:
condition:
text_sensor.state:
state: "on"
then:
- output.turn_on: "${hostname}_led_2"
- if:
condition:
text_sensor.state:
state: "off"
then:
- output.turn_off: "${hostname}_led_2"
Thank you very much, although it still says on compile that “On” & “Off” has not been declared which is odd, but at least I feel like with your bit of code, I am now a 1000 miles closer to solving it.
