Hi Phil,
Thanks for the answer!
I’ve been working with Hass.io on my RPi 4 for about 4-6 weeks now.
I’ve gotten to the point where I need to split up a few things in my config, and these all work:
group: !include groups.yaml
script: !include scripts.yaml
sensor: !include sensors.yaml
panel_custom: !include panel_custom.yaml
So, as I’m attempting to put some Hikvision binary sensors in, I added a section:
binary_sensor: !include binary_sensors.yaml
This doesn’t work…either with a camera binary sensor, or any other. In fact, the config check is OK, but upon restarting, I get a message “lyric can’t start” (or words to that effect).
As my lyric is the custom component that many people use, and the fact that adding a binary_sensor breaks it, makes me wonder if the lyric custom component has a binary_sensor:
definition somewhere in it. Is Hass telling me “we’ve already defined the binary_sensor declaration somewhere else, so you can’t do another one here”?
The only other thing I could think of was that the following entries in my configuration.yaml may, themselves, already declared a binary_sensor, so, again, adding another declaration would be redundant? Here are the other entries:
default_config:
python_script:
zeroconf:
discovery:
ios:
If I find a binary_sensor: section in the lyric code, I could break it out to my binary_sensors.yaml and have all the binary_sensors in one spot.
I’ll let you know what I figure out…but please reply if you’ve got more info. I can’t believe I’m discovering something nobody else has, so it’s certainly possible it’s a noob issue! ![:smiley: :smiley:](https://community.home-assistant.io/images/emoji/twitter/smiley.png?v=9)
Thanks,
Ambi
