I have been trying to build a automation that when doorbell is rang, the camera takes a picture and an e-mail is send.
I added in Config YAML my e-mail settings:
notify:
- name: "email_1"
platform: smtp
sender: "[email protected] "
recipient: "[email protected] "
server: mail.xx.com
port: 465
username: xxxx
password: "XxXxX"
encryption: tls
As per instructions I found on this site.
Then I created an automation:
When YAML:
platform: device
device_id: 67e9fdb1a48b4cd68a892a869e524579
domain: rfxtrx
type: command
subtype: "On"
Then do (part 1):
Camera āTake snapshotā on Voordeur RZW 33 YAML:
service: camera.snapshot
metadata: {}
filename: /config/www/images/doorbell_last_image.jpg
entity_id: camera.voordeur_rzw33_high
Then do (part 2)
Call a service āNotifications: Send a notification with email_1ā
service: notify.email_1
message: Er staat iemand voor de deur
title: Voordeur On
image:
- local/images/doorbell_last_image.jpg
When I run the last bit I get:
Error running action
extra keys not allowed @ data[āimageā]. Got None
Tried also at image:
Same error.
I have no clue how to get a simple mail notification working, I was told HA would be simpler the Domoticzā¦
Hope that there is someone who can assist and let me know how I get this working.
Thank you!
Try this:
title: Voordeur On
images:
- /local/images/doorbell_last_image.jpg
Thanks!
Tried it and get:
Unknown error
When I check the Traces I see this message:
Error: please run connect() first
Any other thoughts on how to get this working? All the support is much appreciated!
Looking at my working snapshot examples, the path used between creating the snapshot and using the snapshot is the same
metadata: {}
and then
title: Voordeur On
image:
- /config/www/images/doorbell_last_image.jpg
Now that being said the error isnāt very descriptive and Iām not familiar with email notification, I use Pushover to my phone with this:
- service: camera.snapshot
metadata: {}
filename: /config/www/snapshot/"{{ trigger.from_state.name }}".jpg
entity_id: camera.driveway_snapshots_clear
- service: notify.pushover
metadata: {}
message: Motion Detected by Reolink Camera
title: >-
{{ trigger.from_state.name }} at {{ now().strftime('%Y-%m-%d') }} {{
now().strftime('%H:%M') }}
target: Samsung-S20
attachment: /config/www/snapshot/"{{ trigger.from_state.name }}".jpg
Did also try the same path, same error.
Is there a way to test the SMTP connection?
BambamNZ
(David)
June 6, 2024, 10:07pm
6
I would start by sending an basic email no attachment and build from there, Iām not aware of any method to test e-mail from within HA
I just did that, just e-mail when light is switched on or of.
Same error:
No clue what it is
This is a Python error related to opening the connection to the mail server.
Seems this is more a email connection problem that an automation problem can I suggest we try a few thingsā¦
Did the ISP or email provider provide guidance on the selecting port 465? Using port 465 is regarded as legacy or deprecated. If they provided explicit guidance on that, try changing the encryption to āstarttlsā
Should that not work, change to port 587 again test with either ātlsā or āstarttlsā
From the code snippet I canāt tell which service you are using, so need to try both.
Thanks that confirms my thoughts email connection issue.
I use TLS on port 465, this is how my e-mail client is configured too and there is works fine. I will play around with the email settings and see if I can get this up and running.
Yippee, it is working now.
To get the mail send I needed to add a time out in the SMTP yaml. Also went from tls to starttls just te be more up to date.
notify:
- name: "email_1"
platform: smtp
server: "my_mail_server"
sender: "my_sender"
port: 587
timeout: 15
encryption: starttls
username: "my_username"
password: "my_password"
recipient:
- "my_email_addres"
Picture gets attached. Need to sort out why it is a low quality snapshot.
Thank you for helping out.
