How to increase time after X minutes?
Hi!
In node-red, how do I extend a delay timer by X minutes, if a sensor is triggered?
Let me explain: I have a pir sensor that turns on a light, if another light is turned off and if current time is night time. If these triggers are true, the light is turned on for 5 minutes.
What I really want is that after initial timer start, if sensor is triggered again, add +2 minutes to the light timmer. My PIR sensor has a timeout of 1 minute, so I think adding +1 minute on each ‘detection’ will be fine…but how do I get this?
This is my current flow:
        "id": "c60afa80.acc318",
        "type": "tab",
        "label": "Spot Noturno Copa",
        "disabled": false,
        "info": ""
        "id": "a8581414.fd9928",
        "type": "server-state-changed",
        "z": "c60afa80.acc318",
        "name": "Copa",
        "server": "2ba92c0c.9dae24",
        "version": 4,
        "exposeToHomeAssistant": false,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "entityidfilter": "binary_sensor.sala_de_jantar_pir_occupancy",
        "entityidfiltertype": "exact",
        "outputinitially": false,
        "state_type": "str",
        "haltifstate": "",
        "halt_if_type": "str",
        "halt_if_compare": "is",
        "outputs": 1,
        "output_only_on_state_change": true,
        "for": 0,
        "forType": "num",
        "forUnits": "minutes",
        "ignorePrevStateNull": false,
        "ignorePrevStateUnknown": false,
        "ignorePrevStateUnavailable": false,
        "ignoreCurrentStateUnknown": false,
        "ignoreCurrentStateUnavailable": false,
        "outputProperties": [
                "property": "payload",
                "propertyType": "msg",
                "value": "",
                "valueType": "entityState"
                "property": "data",
                "value": "",
                "valueType": "eventData"
                "property": "topic",
                "value": "",
                "valueType": "triggerId"
        "x": 130,
        "y": 280,
        "wires": [
                "c44f5425.21fcf8",
                "b3e460bc.40055"
        "id": "c1778193.e6f73",
        "type": "time-range-switch",
        "name": "",
        "lat": "-20.5414",
        "lon": "-47.4025",
        "startTime": "21:00",
        "endTime": "07:00",
        "startOffset": 0,
        "endOffset": 0,
        "x": 570,
        "y": 200,
        "wires": [
                "7426341644098565"
        "id": "eba96d0.1bb539",
        "type": "delay",
        "name": "",
        "pauseType": "delay",
        "timeout": "5",
        "timeoutUnits": "minutes",
        "rate": "1",
        "nbRateUnits": "1",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": false,
        "outputs": 1,
        "x": 1400,
        "y": 420,
        "wires": [
                "40bad5b1.cccd0c"
        "id": "9686ccb3.00f14",
        "type": "api-call-service",
        "name": "Liga Spot Copa",
        "version": 5,
        "debugenabled": false,
        "domain": "light",
        "service": "turn_on",
        "areaId": [],
        "deviceId": [],
        "entityId": [
            "light.sala_de_jantar_spot_4"
        "data": "{\"brightness_pct\": 20, \"color_temp\": 370}",
        "dataType": "json",
        "mergeContext": "",
        "mustacheAltTags": false,
        "outputProperties": [],
        "queue": "none",
        "x": 1420,
        "y": 300,
        "wires": [
                "eba96d0.1bb539"
        "id": "40bad5b1.cccd0c",
        "name": "Desliga Spot Copa",
        "version": 5,
        "domain": "light",
        "service": "turn_off",
        "areaId": [],
        "deviceId": [],
        "entityId": [
        "data": "",
        "dataType": "json",
        "mergeContext": "",
        "queue": "none",
        "x": 1630,
        "y": 540,
        "wires": [
        "id": "c44f5425.21fcf8",
        "type": "switch",
        "name": "",
        "rules": [
                "t": "eq",
                "v": "on",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 360,
        "y": 280,
        "wires": [
                "c1778193.e6f73"
        "id": "5b1fb03.82bfb5",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 1200,
        "y": 100,
        "wires": [
                "9686ccb3.00f14"
        "id": "ebac1854.ba02f8",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 1340,
        "y": 600,
        "wires": [
                "40bad5b1.cccd0c"
        "id": "b3e460bc.40055",
        "type": "debug",
        "name": "",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 390,
        "y": 560,
        "wires": []
        "id": "7426341644098565",
        "type": "api-current-state",
        "name": "",
        "version": 3,
        "outputs": 2,
        "halt_if": "off",
        "entity_id": "light.sala_de_jantar_spot_1",
        "blockInputOverrides": false,
                "value": "",
                "property": "data",
                "value": "",
                "valueType": "entity"
        "for": 0,
        "forType": "num",
        "x": 920,
        "y": 240,
        "wires": [
                "cdbd8749a13089f1"
        "id": "cdbd8749a13089f1",
        "name": "",
        "version": 3,
        "outputs": 2,
        "halt_if": "off",
        "entity_id": "light.sala_de_jantar_spot_2",
                "value": "",
                "property": "data",
                "value": "",
        "for": 0,
        "forType": "num",
        "x": 920,
        "y": 300,
        "wires": [
                "d159f89173b2d36e"
        "id": "d159f89173b2d36e",
        "name": "",
        "version": 3,
        "outputs": 2,
        "halt_if": "off",
        "entity_id": "light.sala_de_jantar_spot_3",
                "value": "",
                "property": "data",
                "value": "",
        "for": 0,
        "forType": "num",
        "x": 920,
        "y": 360,
        "wires": [
                "86dea2d728940e94"
        "id": "86dea2d728940e94",
        "name": "Luz Sala desligada",
        "version": 3,
        "outputs": 2,
        "halt_if": "off",
        "entity_id": "light.interruptor_sala",
                "value": "",
                "property": "data",
                "value": "",
        "for": 0,
        "forType": "num",
        "x": 990,
        "y": 420,
        "wires": [
                "4e6d019ea6ac4dd2"
        "id": "4e6d019ea6ac4dd2",
        "name": "Luz Cozinha desligada",
        "version": 3,
        "outputs": 2,
        "halt_if": "off",
        "entity_id": "light.luz_cozinha",
                "value": "",
                "property": "data",
                "value": "",
        "for": 0,
        "forType": "num",
        "x": 980,
        "y": 480,
        "wires": [
                "9686ccb3.00f14"
        "id": "2ba92c0c.9dae24",
        "type": "server",
        "name": "Home Assistant",
        "version": 2,
        "addon": true,
        "rejectUnauthorizedCerts": true,
        "ha_boolean": "y|yes|true|on|home|open",
        "connectionDelay": true,
        "cacheJson": true,
        "heartbeat": false,
        "heartbeatInterval": 30
instead of a delay node you could use varidelay. You’ll have control over the remaining time of the timer thus allowing you to add the desired amount of extra time.
there might be a better way, but I believe this will behave as you expect
[{"id":"c80f74b6.9ee688","type":"trigger-state","z":"c60afa80.acc318","name":"triggers","server":"9405c3fe.d0a6c","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"binary_sensor.sala_de_jantar_pir_occupancy","entityidfiltertype":"exact","debugenabled":false,"constraints":[{"targetType":"entity_id","targetValue":"light.sala_de_jantar_spot_1","propertyType":"current_state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"off","propertyValue":"new_state.state"},{"targetType":"entity_id","targetValue":"light.sala_de_jantar_spot_2","propertyType":"current_state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"off","propertyValue":"new_state.state"},{"targetType":"entity_id","targetValue":"light.sala_de_jantar_spot_3","propertyType":"current_state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"off","propertyValue":"new_state.state"},{"targetType":"entity_id","targetValue":"light.interruptor_sala","propertyType":"current_state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"off","propertyValue":"new_state.state"},{"targetType":"entity_id","targetValue":"light.luz_cozinha","propertyType":"current_state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"off","propertyValue":"new_state.state"},{"targetType":"this_entity","targetValue":"","propertyType":"current_state","comparatorType":"is","comparatorValueDatatype":"str","comparatorValue":"on","propertyValue":"new_state.state"}],"inputs":0,"outputs":2,"customoutputs":[],"outputinitially":false,"state_type":"str","enableInput":false,"x":190,"y":800,"wires":[["d26bf184.fac2c"],[]]},{"id":"d26bf184.fac2c","type":"time-range-switch","z":"c60afa80.acc318","name":"","lat":"-20.5414","lon":"-47.4025","startTime":"21:00","endTime":"07:00","startOffset":0,"endOffset":0,"x":330,"y":800,"wires":[["a2f55d4c.e6829"],[]]},{"id":"a2f55d4c.e6829","type":"api-call-service","z":"c60afa80.acc318","name":"Liga Spot Copa","server":"2ba92c0c.9dae24","version":5,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":["light.sala_de_jantar_spot_4"],"data":"{\"brightness_pct\": 20, \"color_temp\": 370}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":500,"y":800,"wires":[["d0bb29b9.0f8c08"]]},{"id":"4f422984.e1c2a8","type":"stoptimer-varidelay","z":"c60afa80.acc318","duration":"5","durationType":"num","units":"Second","payloadtype":"num","payloadval":"0","name":"","reporting":"every_second","persist":true,"x":1020,"y":800,"wires":[["457a2cd0.7b2814"],[],["85c357ef.d43968"]]},{"id":"85c357ef.d43968","type":"ha-entity","z":"c60afa80.acc318","name":"light flow remaining seconds","server":"9405c3fe.d0a6c","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"light_flow_remaining_seconds"},{"property":"device_class","value":""},{"property":"icon","value":""},{"property":"unit_of_measurement","value":""}],"state":"$round($number($substring(payload,3,2)))*60 + $round($number($substring(payload,6,2)))","stateType":"jsonata","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","outputOnStateChange":false,"outputPayload":"$entity().state ? \"on\": \"off\"","outputPayloadType":"jsonata","x":1260,"y":860,"wires":[[]]},{"id":"457a2cd0.7b2814","type":"api-call-service","z":"c60afa80.acc318","name":"Desliga Spot Copa","server":"2ba92c0c.9dae24","version":5,"debugenabled":false,"service_domain":"light","service":"turn_off","entityId":["light.sala_de_jantar_spot_4"],"data":"","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1230,"y":760,"wires":[[]]},{"id":"d0bb29b9.0f8c08","type":"api-current-state","z":"c60afa80.acc318","name":"remainig time?","server":"9405c3fe.d0a6c","version":3,"outputs":2,"halt_if":"1","halt_if_type":"num","halt_if_compare":"gte","entity_id":"sensor.light_flow_remaining_seconds","state_type":"num","blockInputOverrides":true,"outputProperties":[{"property":"time","propertyType":"msg","value":"","valueType":"entityState"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":680,"y":800,"wires":[["bd84c1c3.d4e83"],["c9ba3be5.c30848"]]},{"id":"bd84c1c3.d4e83","type":"change","z":"c60afa80.acc318","name":"set delay","rules":[{"t":"set","p":"delay","pt":"msg","to":"$number(time) + 120","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":850,"y":780,"wires":[["4f422984.e1c2a8"]]},{"id":"c9ba3be5.c30848","type":"change","z":"c60afa80.acc318","name":"set delay","rules":[{"t":"set","p":"delay","pt":"msg","to":"300","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":850,"y":820,"wires":[["4f422984.e1c2a8"]]},{"id":"9405c3fe.d0a6c","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30},{"id":"2ba92c0c.9dae24","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30}]
I think the easiest way is to just use the merge node.
Each time this node gets a new message it will reset the timer and only send a message further on when the timeout set for the node has been reached without new message arriving to the node.
that’s definetely the easiest
Merge node? Do you mean join node?
No, it is called merge.
Maybe I have installed node-red-contrib-merge manually, but I do not recall so.
billede
billede
It seems to just collect all the message arriving and then first send it when the timeout from the last received message arrive.
If you need to work with the messages arriving, then you might need to do some handling.
The first one would always be msg,payload[0], but the last one would be msg.payload[n], where n is the number of arrived messages before timeout.
A little javascript would quickly solve that issue.
You can achieve the same with the stock trigger node, checking the “Extend Delay If New Message Arrives” and “Send Second Message To Separate Output
[{"id":"29eeb24a.15fc9e","type":"inject","z":"937ef78.ec6b408","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":210,"y":220,"wires":[["8e18656b.f8edd8"]]},{"id":"8e18656b.f8edd8","type":"trigger","z":"937ef78.ec6b408","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"5","extend":true,"overrideDelay":false,"units":"min","reset":"","bytopic":"all","topic":"topic","outputs":2,"x":360,"y":220,"wires":[["83ab9bbb.d912a8"],["da436cfc.d4fc5"]]},{"id":"83ab9bbb.d912a8","type":"api-call-service","z":"937ef78.ec6b408","name":"turn on","server":"9405c3fe.d0a6c","version":3,"debugenabled":false,"service_domain":"","service":"","entityId":"","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":520,"y":200,"wires":[["5323d591.91404c"]]},{"id":"da436cfc.d4fc5","type":"api-call-service","z":"937ef78.ec6b408","name":"turn off","server":"9405c3fe.d0a6c","version":3,"debugenabled":false,"service_domain":"","service":"","entityId":"","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":530,"y":240,"wires":[["59bd88c0.998b78"]]},{"id":"5323d591.91404c","type":"debug","z":"937ef78.ec6b408","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":650,"y":200,"wires":[]},{"id":"59bd88c0.998b78","type":"debug","z":"937ef78.ec6b408","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":650,"y":240,"wires":[]},{"id":"9405c3fe.d0a6c","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30}]
