I want to increase variable max_badtemp in a script with 0.5.
I can’t get t to work. Any suggestions?
Please don’t post pictures of text. Post the properly formatted text.
Also variables are local to a script/automation. So the variable can’t be used outside the script.
Also you have variables declared twice.
Thanks, this is the changed code ( still not working).
Variable max_badtemp is defined in config (before scripts)
badtemp_op:
alias: Badtemperatuur ophogen
sequence:
- service: variable.set_variable
variable: max_badtemp
value: “{{ variable.max_badtemp + 1 }}”
mode: single
