Hola! I know technically this is not the right forum for my question, but hoping some of you reading this might be able to point me in the right direction.
Running HomeAssistant, frigate docker and OPNsense on an old computer. Everything is/was running great! I now want to install a new PCIe card with a coral TPU for frigate to use. I just can’t figure out how to do so!
When I try to google for help pretty much all the results are about PCIe passthrough, which I will have to do eventually but at the moment I need to be able to boot the machine first.
Original install of proxmox, HA and frigate was done using the integrated NIC. I then added a PCIe with two NICs which I am using for OPNsense.
On my first try, when booting with PCIe with coral TPU both the integrated NIC and the PCIe with NICs wouldn’t show any activity (no lights blinking). If I removed the PCIe with the Coral machine would boot up normally.
I then decided to swap the PCIe slots. I put the PCIe with the NICs where I had the Coral TPU PCIe connected and vice versa. This time when I boot the PCIe with the NICs does show activity. In fact I an boot up the machine and OPNsense works great. However the integrated NIC still doesn’t show any activity, and since that is the NIC used for home assistant and proxmox web server I am not able to log in.
All that said, any ideas on how I can properly install the PCIe with Coral TPU?
