How to install an Add-On (Telegram VOIP calls) on Hassbian
Hello, I would like to install this addon: Telegram VOIP Calls on my Hassbian but I cannot understand the way to do this. Before I had Home Assistant inside a Docker on Raspbian and I could simply add the GIT Repository and install the Add-On, but on Hassbian there is no Add-On section and I am kind of lost…
Thank you very much in advance,
Dario
If you want hassio, you have to install hassio. What you have installed is Hassbian. It is Home Assistant running in a python virtual environment. It is not Home Assistant running on the hassio platform.
Add-ons are ONLY available on Hassio.
Only Hass.io has add-ons, so if you want add-ons you’ll need to migrate to Hass.io I’m afraid.
However, add-ons are largely just Docker containers for applications. Applications that you can install manually. Unfortunately it’s not clear how the author of that add-on created their application, but I’m sure if you reach out to them they can help you.
I want to install this addon and i have Hassio ( with supervisor) how i can install that?
