How to install APK packages?
@CountParadox is correct.
You can install an apk more or less permanently by using the web terminal & ssh addon. Then it gets installed on every ha start. Similarly with a script.
There is an effort to produce an addon here, but you’ll need to adapt. Checkmk 2.0 network monitoring add-on WIP
